Alt 27.05.2020, 07:53   #1
dmpatanis
Standard Liqui moly engine cleaner
Hello i have cuore L701 with 175.000km and i consider if its ok to use Liquid moly engine cleaner inthe next oil replacement.
What do you think?
dmpatanis ist offline   Mit Zitat antworten
Alt 27.05.2020, 09:22   #2
Bauer_Sucht_Sau
I think, this is an engine flush chemical. Such are intended for short term use only. After use, it's important to replace the oil filter also
Alt 28.05.2020, 20:57   #3
Why should you use such a chemical? Any reason?
It is always a Risk to flush the engine. I would rather recommend to use a good fully synthetic Oil and to change that regularly and in no case too late.
If it is an engine flush, it can damage the bearings of the engine if not applied correctly.
I'd invest the money rather in a good engine oil and frequent oil changes.
Ich teste Liqui-Moly´s Ceratec-Additiv Movement L901 Allgemein 46 24.06.2021 11:47
Engine flush henri Die YRV Serie 5 27.01.2015 17:10
A101 What to do? Engine compression 5.5 ! kamango Die Applause Serie 0 17.03.2009 20:26
Hijet engine CrashGTTi Die HiJet Serie 5 09.07.2007 15:41
Engine size Peter_KTP Die Charade Serie 0 08.01.2005 22:55
Alle Zeitangaben in WEZ +2. Es ist jetzt 01:20 Uhr.
