Alt 27.02.2020, 11:58   #1
dmpatanis
Standard Cuore L701 rear breaks
Hello when i go reversing with my cuore L7 and push break my rear drum make a noise of skouiz.
How i can repair this noise?
dmpatanis ist offline   Mit Zitat antworten
Alt 27.02.2020, 22:31   #2
I guess this is quite normal for drum brakes used in reverse.
When braking, this type of brakes wears out a bit so that the friction parts fit together very exactly and uniquely. When they are then used the opposite direction than normal, that causes sometimes noises and can also result in less powerful braking.
That is normal for drum brakes and not related to any damage.
To calm you, you can remove the rear whels and the outer part which closes the brake drum and see if everything is fine. But normally the rear brake drums last as long as the rest of the Cuore...
Alt 27.02.2020, 22:38   #3
dmpatanis
Thanks very much.
Rear roof spoiler L7 dmpatanis Die Cuore Serie 12 19.02.2020 06:41
rear ausgang beim original head unit totalhappy Die Materia Serie 11 28.05.2009 09:36
Alle Zeitangaben in WEZ +2. Es ist jetzt 18:27 Uhr.
